How To Upgrade HDCVI firmware
Any HDCVI DVR should always be operating on the latest firmware version available.
If you are experiencing intermittent connectivity to the internet, general bugginess or difficulty using any feature, you must make sure there is no available firmware update which would indicate you are not on the latest version.
There are 2 ways to check for your DVR firmware version:
1. On the DVR's built-in interface, from the Main Menu, navigate to System(in the Info row)->Version.
2. On the web interface, log in, then click the "i" icon in the top right corner and you will land on the Version page.
The HDCVI DVR cannot be expected to work as advertised unless it is up to date.
Please always make sure you have the latest version before trying any other troubleshooting steps or contacting support.
There are 2 methods to update the firmware on your HDCVI DVR: directly on the DVR or through the web interface.
Method 1: DVR Interface
The safest way to upgrade the DVR is by doing it directly on the device.
First download the most recent firmware from http://www.amcrest.com/firmware-subscribe.
Insert the flash drive into the USB port on the DVR and a window will pop up.
Select the firmware file that you downloaded and click Start. A progress bar will be shown at the bottom of the window. Once the upgrade has finished the DVR might restart on its own.
Method 2: Web Interface
Next login to the DVR's web interface. For more information on how to access the web interface for your DVR click here.
In the web interface, click the setup gear icon in the top right. Then click System on the left panel, then Upgrade below it.
Click the Upgrade button and the upgrade process will begin. A progress bar will appear showing you the progress of the upgrade. Once the upgrade has finished the DVR might Restart on its own.
After upgrading the firmware, it is a good idea to reinstall the plugins. If this is not done automatically, or if you have issues with the web interface, check out this article: Removing Old Plugins
