Amcrest Surveillance Pro - Setting Up PC-NVR
Amcrest Surveillance Pro: Mac OS / Windows
First you will need to add your camera to Amcrest Surveillance Pro.
The storage device through PC-NVR has now been configured. To adjust when the camera records to the HDD, check out how to assign a schedule!
