Adding cameras to additional devices
Amcrest View Pro Setup (Adding cameras to additional devices)
Add your camera to other smart phones or tablets by using the P2P setup method if you’ve initially set up the camera on the internet.
First connect your mobile device to your WiFi and download the app Amcrest View from the App Store or Play Store. Download Amcrest View on your mobile device:
Step 1
Connect the camera to a power supply using the included power adapter. Wait 30 seconds for the camera to start-up and initialize.
Step 2
Connect the camera to the internet, either through a wired or WiFi connection. Either by using the App Setup method or Desktop Access Setup method.
Step 3
Step 4
Tab the menu icon  IMG_5249.PNG on the top left to open the menu.
Step 5
Now select “Device Manager” from the menu.
Step 6
Device Manager will appear. Tap the plus icon  IMG_5250.PNG on the top right or tap "Add Device".
Step 7
Select the device type you will be connecting to Amcrest View.
Step 8
Select your connection type, in this case select the right tab Add Connected Device to display P2P Setup.
Then select P2P Setup to begin adding a camera you’ve already connected to the network.
Step 9
The camera will open on your mobile device to scan the QR code located on the device you’re adding to Amcrest View. Alternatively, you can enter in the Serial Number manually. Your mobile device may request permissions to allow the application to use your camera. Once accepted your mobile device will then be ready to scan the QR code.
Step 10
Once the QR code is scanned or the serial number has been added to your app, you will then be prompted to give your camera a name. This name can be unique to your camera and can be named anything you wish. After you name your camera, please enter the camera's username and password. The default username and password is admin. Once this information is entered, please press "Start Live View" to continue.
The live stream from your camera will be presented in the Live View screen.
