Installation Guide
Installation Guide For The IP2M-853E
The camera has 4 standard camera tripod screw hole (1/4-20 UNC thread) for use in mounting the camera onto a stable surface.
Note: Prior to installation ensure that the installation environment can support at least 3 times the weight of the camera.
When accessing your camera, you will notice a few additional wiring connections associated with the device. These connections contain a power connection and ground, an Ethernet connection, audio wires, and alarm wiring.
POWER - This connection is optional for this device since the device will draw power via an Ethernet cable (PoE) however, the option is there. The camera will require a basic 12V DC power adapter. This wire also has a optional grounding (EARTH) wire for additional grounding of the unit.
Ethernet Connection - This connection is used to transmit data and transmit PoE power to the unit. The unit is PoE + (802.3at) compatible.
AUDIO - This connection provides two-way audio to the unit. The red wire is for AUDIO OUT, the white wire is for AUDIO IN, and the black wire is there to ground the audio.
ALARM - This connection provides alarm in and alarm out features to an external alarm or security system. The basic overview of these wires are as follows:
Blue - Alarm OUT1
Green - Alarm COM1 (Communication Port)
Yellow & Green - Alarm Ground
Red - Alarm IN1 Brown Alarm IN2
