Amcrest Surveillance Pro (IPM-HX1)
The below link will open up a download for the .exe (or executable program) that will allow you to install the Amcrest Surveillance Pro client for Windows computers. Please note that you need to double-click the file that you download to your computer to "run" the installer. After it is finished installing, there should be a shortcut on your desktop to launch Amcrest Surveillance Pro.
For Windows:
Amcrest Surveillance Pro for Windows
For Macintosh:
Amcrest Surveillance Pro for Macintosh
Once you've gotten the program up and running, you can use the Amcrest Surveillance Pro User Manual in order to learn how to add cameras, configure and manage them.
Please click here to download the .PDF: Amcrest Surveillance Pro User Manual Download (PDF)
