Amcrest Surveillance Pro - Multi-Device Viewing (IPM-HX1)
Amcrest cameras have a variety of viewers available as well as storage types that are supported. One of which uses Amcrest Surveillance Pro desktop application. This article will cover connecting your camera to the application.
First you will need to add your cameras to Amcrest Surveillance Pro.
Once your cameras have been added to Surveillance Pro we can begin viewing them live! Go back to the main menu.
There are multiple viewing options available: 1, 4, 6, 8, 9, 16, 25, 36, 64, or Custom Split.
To create a custom viewing option click  and the "Custom Layout" window will appear. Using the grid you can adjust the layout you prefer, whether it's for 2 cameras or more! Simply click "Ok" to finish creating the layout and apply it to your live view pane. Once again selecting one of the boxes and double clicking on a camera will display the video feed.
