Car DVR Spec Sheet (ACD-830B)
Amcrest ACD-860B Dash Camera Feature Set and Specifications
The Amcrest ACD-830B is a very versatile dash camera that has several features and specifications in three different camera modes. The following lists are the video, still image and playback features and specifications:
Video Features
MicroSD Card: Supports up to 64GB Class 10, minimum is 4GB Class 10.
Quick Lock: Quickly lock a video while it is still recording.
GPS: Global Positioning System for location and speed monitoring (GPS Module sold separately).
Mini HDMI: Display video from the camera straight to an external display via Mini HDMI.
Video Recording Resolutions: 1080P, 720P, WVGA, and VGA.
Audio: Enable or disable audio for video recording.
Loop Record: Automatically loop recordings and segment them in 3, 5, or 10 minute durations.
Time Lapse Record: Record in time lapse to review footage in time lapse format.
WDR (Wide Dynamic Range): Record in Wide Dynamic Range to capture the best light exposure between different objects.
Motion Detection: Records when camera detects motion.
Date Stamp: Allow the date and time to be captured with recorded footage.
Plate Number: Allows your license plate number to be displayed in video playback.
Accident Sensor: Allows camera to lock the video being recorded during a vehicle collision.
Parking Sensor: Allows camera to power on, to then record and lock video.
Still Image Features
Still Image Resolutions: 3MP, 2MP, VGA, and 1.3MP.
Capture Timer: Enable capture timer to time image capturing.
Burst Shot: Take 3 or 5 consecutive photos in one instance.
Anti-Shake: Take photos with image stabilization.
Quick Review: Temporarily display the picture after it has been taken.
Date Stamp: Allow the date and time to be captured with still images.
Playback Features
Delete: Delete content from MicroSD card using the camera interface.
Protect: Protect files that are written to the MicroSD Card.
Slide Show: View a slide show with 2, 5, or 10 seconds in between images and videos.
Specifications
Feature
Description
Model
ACD-830B
CPU
432MHZ Micro-Processor
SDRAM
Built-in
Loud Speaker
Built-in
Microphone
Built-in
Storage
via Micro SD Card Slot only
Micro SD
Max 64GB Class 10, Min 4GB Class 10
Quick Lock Button
Built-in
GPS
GPS compatibility using Mini HDMI port (GPS Module sold separately)
Battery
Built-in Rechargeable 3.7V, 200mAh Lithium Ion
Power Supply
Output: Mini USB 5V 1.5A; Input: Car Adaptor Socket 12-24V
Image Sensor
WDR Sony IMX322
Lens Size
160-degree wide viewing angle
Display
3.0 inch TFT 240 x 960 LCD screen
Video Resolution
1080 FHD 1920*1080 / 720P 1280*720 / WVGA 848*480 / VGA 640*480
Loop Recording
3 min, 5 min, 10 min
Accident Sensor
Accelerometer Impact Detection
Parking Sensor
Accelerometer Vibration Detection
Motion Detection
Pixel Motion Detection
Auto Power Off
Delay shut off for 3, 5, or 10 Minutes
Video Format
MOV H.264
Image Format
JPG
Image Resolution
3MP, 2MP, 1.3MP, VGA
Display Output
Mini HDMI
Reset Button
Built-in
Working Temperature
-4 ° F ~ +149 ° F
