Push Notification Setup on Amcrest View Pro (iPhone & Android)
First, open the Amcrest View Pro app open and ensure your camera is added to the Device Manager.
1. Tap the top left icon to open the menu.
3. Tap Configuration.
    • HDD Alarm: Select if you want to receive notifications that no disk is detected, there is low space on the disk, or the disk has an error. (In this case the SD Card that's inserted within the camera.)
1 out of 2 found this helpful
