HD-CVI vs Eco HD-CVI (720p HD-CVI)
The standard HD-CVI DVR's and Eco HD-CVI DVR's have minor differences:
  • The Eco HD-CVI DVR is smaller and has no support for a remote controller.
  • The major difference is the sensor. Standard HD-CVI will have better image quality and a wider angle of view than the Eco HD-CVI.
DVRHD-CVIEco HD-CVI
Appearance Mini 1U Box - Metal Housing Compact 1U Box - Plastic Housing
Capacity
All Channel 720p realtime
& 1080p non-realtime recording
All channel 720P recording
CameraHD-CVIEco HD-CVI
Sensor 1/2.9" 1MP CMOS 1/4" 1MP CMOS
Angle of View 88° 61°
1 out of 1 found this helpful
