Push Notification Setup on Amcrest View Pro (iPhone & Android) (NVR)
First you need to have the Amcrest View Pro app open and your camera/DVR/NVR added.
1. Tap the top left icon to open the menu.
2. Tap the Push notifications option.
3. Tap Push Config.
    • Push Type: This is what will open when you tap on the push notifications you receive.
    • Cam Mask: Select if you want to receive notifications that the camera has been covered or has had its ability to view blocked.
    • Local Alarm: Select if you want to be notified that a local alarm has been triggered. (This referring to the more traditional I/O alarm ports on the back of the device.)
    • HDD Alarm: Select if you want to receive notifications that no disk is detected, there is low space on the disk, or the disk has an error.
To view a list of all of the events, under Alarm Manger (steps 1 & 2 above), select Event List.
3 out of 8 found this helpful
