What Is LDC and How Does It Affect The Camera's Field of View?
This model features built-in LDC, this feature allows the user to adjust lens distortion correction. Lens distortions typically occur when using wide angle lenses, LDC works to automatically correct these distortions allowing the captured video to match a more real-world setting which helps to deliver an optimal viewing experience.
By default, LDC will be enabled on your device. This correction will allow the camera to view the area in a 170° horizontal, 75° vertical and 175° diagonal viewing angle, however, disabling this feature will allow the camera to view the area is a full 180° horizontal, 78° vertical, and 180° diagonal viewing angle. If you would like to disable LDC or access its features, please refer to the information provided below.
Step 1: Log in to the web user interface (web UI) for your camera. For more information on how to access the web UI for your camera click here.
Step 2: Click on Setup>>Camera>>Configuration>>LDC.
Step 3: To disable LDC, select the OFF option and click Save.
For more information on the options in this menu, please refer to the information below.
Profile: This dropdown box allows the user to select which profile to modify. The 3 options are Day, Night, and General.
LDC: Enable or disable lens distortion correction.
Correction Strength: Adjust the distortion correction value. The values range from 0 to 100, 50 is the default value.
Far-end Amplification: Correct lens distortion. 0 is the lowest correction level, and 3 is the highest. It will be 0 by default.
Horizontal Zoom: Zoom the image horizontally. The default value is 50, however, can range from 0 to 100.
Vertical Zoom: Zoom the image vertically. The default value is 50, however, can range from 0 to 100.
